Ir para o conteúdo principal
Acer Aspire V5-591G-75KE Hard Drive Replacement
O que você precisa
  1. Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, imagem 1 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, imagem 2 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement, Acer Aspire V5-591G-75KE Disassembly: passo 1, imagem 3 %32
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 2, imagem 1 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 2, imagem 2 %32
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 3, imagem 1 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 3, imagem 2 %32
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 4, imagem 1 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 4, imagem 2 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement: passo 4, imagem 3 %32
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32 Acer Aspire V5-591G-75KE Hard Drive Replacement, Hard Drive: passo 5, imagem 3 %32
    • Using the plastic tabs, lift the hard drive slightly and pull to the left.
    • Remove the rubber mounting brackets from the hard drive.
    • If you are replacing your hard drive with a new one, please note you will need to reuse the rubber mounting brackets in order to secure it in place.
Conclusão
Uma outra pessoa concluiu este guia.
Reina Godeck
Membro desde: 10/16/17
741 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S3-G5, Liner Fall 2017 Membro de UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,093
