Introdução
The Acer Aspire V5-591G-75KE is manufactured with a Seagate 1 TB 2.5-Inch SATA III 5400rpm Hard Drive.
If you replace the hard drive, make sure it observes the 2.5-Inch dimensions in order to use the rubber mounting brackets that secure the drive in place.
O que você precisa
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
Using the plastic tabs, lift the hard drive slightly and pull to the left.
Remove the rubber mounting brackets from the hard drive.
Uma outra pessoa concluiu este guia.
