Ir para o conteúdo principal
Acer Aspire V5-591G-75KE Disassembly
O que você precisa
  1. Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: passo 1, imagem 1 %32 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: passo 1, imagem 2 %32 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: passo 1, imagem 3 %32
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Disassembly: passo 2, imagem 1 %32 Acer Aspire V5-591G-75KE Disassembly: passo 2, imagem 2 %32
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Disassembly: passo 3, imagem 1 %32 Acer Aspire V5-591G-75KE Disassembly: passo 3, imagem 2 %32
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Disassembly: passo 4, imagem 1 %32 Acer Aspire V5-591G-75KE Disassembly: passo 4, imagem 2 %32 Acer Aspire V5-591G-75KE Disassembly: passo 4, imagem 3 %32
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
Conclusão
Uma outra pessoa concluiu este guia.
Tasier Hagler
Membro desde: 10/18/17
428 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S3-G5, Liner Fall 2017 Membro de UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 25
Duração total: 4,012
