Ir para o conteúdo principal
Acer Aspire V5-572 Cooling / Fan System Replacement
O que você precisa
  1. Acer Aspire V5-572 Cooling / Fan System Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 Cooling / Fan System Replacement: passo 2, imagem 1 %32
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 Cooling / Fan System Replacement: passo 3, imagem 1 %32 Acer Aspire V5-572 Cooling / Fan System Replacement: passo 3, imagem 2 %32 Acer Aspire V5-572 Cooling / Fan System Replacement: passo 3, imagem 3 %32
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 Cooling / Fan System Replacement: passo 4, imagem 1 %32
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572 Cooling / Fan System Replacement, Cooling / Fan System: passo 5, imagem 1 %32 Acer Aspire V5-572 Cooling / Fan System Replacement, Cooling / Fan System: passo 5, imagem 2 %32
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
Conclusão
ZFix
Membro desde: 12/09/13
194.135 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
326 Membros
Autoria de 1.671 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 2,763
