Ir para o conteúdo principal
Acer Aspire V5-571P-6815 Touchscreen Replacement
O que você precisa
  1. Acer Aspire V5-571P-6815 Touchscreen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 2, imagem 2 %32
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: passo 3, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: passo 3, imagem 2 %32
    • Insert a plastic opening tool between the screen and lid.
    • Work the plastic opening tool around the perimeter while prying upwards until the screen separates from the lid.
  4. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 4, imagem 1 %32
    • Lay the screen flat down on the keyboard.
  5. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 5, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 5, imagem 2 %32
    • Remove the camera using a pair of blunt nose tweezers.
    • Peel up the adhesive tape keeping the camera's cable tied down.
  6. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 6, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 6, imagem 2 %32
    • Remove the microphone from the motherboard with a pair of blunt nose tweezers.
    • Slide out the adhesive tape securing the microphone cable.
  7. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 7, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 7, imagem 2 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 7, imagem 3 %32
    • Lift up the ribbon cable contained by the adhesive strip with blunt nose tweezers.
    • This will allow you to access the two black digitizer ribbons.
    • Use a spudger to flip up the retaining flap on the digitizer ribbon cable ZIF socket.
    • Pull the ribbon cables out of their sockets.
  8. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 8, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 8, imagem 2 %32
    • Remove the board from the laptop.
  9. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 9, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 9, imagem 2 %32
    • Use the blunt nose tweezers to peel up the adhesive on the display cable.
    • Pull on the adhesive tape to disconnect the display from the motherboard.
  10. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 10, imagem 1 %32 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 10, imagem 2 %32
    • Lift the whole strip connected to the circuit board and LCD connector. Place the strip to the side where it is not in contact with the screen.
    • Remove the whole screen from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Brianna Sinder
Membro desde: 04/12/18
377 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G4, Liner Spring 2018 Membro de UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
Membros da 5
Autoria de 8 guias
Um comentário
The heading of your Procedure is “Acer Aspire V5-571P-6815 Touchscreen Replacement” BUT you just opened up the entire screen.
NOTE: you didn’t separate the “TOUCH SCREEN” from the LCD screen.
This supposed to be the most important part of your procedure item ! ! ! !
PLEASE……. ******
KaivitiSingh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 3,379
