Ir para o conteúdo principal
Acer Aspire V5-571P-6815 Charging Port Replacement
O que você precisa
  1. Acer Aspire V5-571P-6815 Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 2, imagem 2 %32
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Charging Port Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  4. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 4, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 4, imagem 2 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 4, imagem 3 %32
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  5. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 5, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 5, imagem 2 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 5, imagem 3 %32
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
  6. Acer Aspire V5-571P-6815 Charging Port Replacement, Charging Port: passo 6, imagem 1 %32
    • Remove the six 6mm Phillips #0 screws from underneath the keyboard.
  7. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 7, imagem 1 %32
    • Remove the sixteen 6mm Phillips #0 screws from the bottom cover.
  8. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 8, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 8, imagem 2 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 8, imagem 3 %32
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    • Pull the ribbon cable from the socket.
  9. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 9, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 9, imagem 2 %32
  10. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 10, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 10, imagem 2 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 10, imagem 3 %32
    • Use a plastic opening tool to pry up the palm rest from the laptop body.
    • Remove the palm rest from the laptop.
  11. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 11, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 11, imagem 2 %32
    • Disconnect the charging port cable from the motherboard.
    • You might have to remove some electrical tape that is in the way.
  12. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 12, imagem 1 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 12, imagem 2 %32 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 12, imagem 3 %32
    • Lift the charging port up and out of the laptop.
Conclusão
Follow the steps in reverse with a new cable.
Uma outra pessoa concluiu este guia.
Gordon Tran
Membro desde: 04/12/18
225 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G4, Liner Spring 2018 Membro de UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 27
Duração total: 5,512
