Ir para o conteúdo principal
Acer Aspire V5-571-6891 Keyboard Replacement
O que você precisa
  1. Acer Aspire V5-571-6891 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Keyboard Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571-6891 Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  4. Acer Aspire V5-571-6891 Keyboard Replacement: passo 4, imagem 1 %32
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  5. Acer Aspire V5-571-6891 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire V5-571-6891 Keyboard Replacement: passo 5, imagem 2 %32
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  6. Acer Aspire V5-571-6891 Keyboard Replacement: passo 6, imagem 1 %32
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  7. Acer Aspire V5-571-6891 Keyboard Replacement: passo 7, imagem 1 %32
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 21
Duração total: 696
