Ir para o conteúdo principal
Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement
O que você precisa
  1. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Battery: passo 1, imagem 1 %32
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 2, imagem 2 %32
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  4. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 4, imagem 1 %32
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  5. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 5, imagem 1 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 5, imagem 2 %32
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  6. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 6, imagem 1 %32
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  7. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 7, imagem 1 %32
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
  8. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): passo 8, imagem 1 %32
    • Remove the five 6mm PH1 screws beneath the keyboard.
  9. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 9, imagem 1 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 9, imagem 2 %32
    • Use the spudger to pop the gray tab up and away from the far left wire strip.
    • Disconnect the wire strip by pulling the blue tab loose.
  10. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 10, imagem 1 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 10, imagem 2 %32
    • Use the spudger to pop the white tab up away from the wire strip located at the top left corner of the mouse pad.
    • Disconnect the wire strip by pulling the blue tab.
  11. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 11, imagem 1 %32
    • Close the laptop.
    • Remove the remaining 18 6mm PH1 screws from the bottom cover of the laptop.
  12. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 12, imagem 1 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 12, imagem 2 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 12, imagem 3 %32
    • Use the opening tool to separate the back of the laptop from the inside cover.
    • Open the computer and remove the inside cover.
  13. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 13, imagem 1 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 13, imagem 2 %32 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: passo 13, imagem 3 %32
    • Lift the HDD out of the base and use the opening tool to disconnect the HDD from the motherboard wire.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 547
