Ir para o conteúdo principal
Acer Aspire V5-571-6889 Motherboard Replacement
O que você precisa
  1. Acer Aspire V5-571-6889 Motherboard Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Motherboard Replacement: passo 2, imagem 1 %32
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Motherboard Replacement: passo 3, imagem 1 %32
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Motherboard Replacement: passo 4, imagem 1 %32
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Motherboard Replacement, Remove Upper Cover: passo 5, imagem 1 %32
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Motherboard Replacement: passo 6, imagem 1 %32
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Acer Aspire V5-571-6889 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm with screw attached to the Motherboard.
  8. Acer Aspire V5-571-6889 Motherboard Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use Tweezers to remove the antenna cables attached to the Wi-Fi card.
  9. Acer Aspire V5-571-6889 Motherboard Replacement: passo 9, imagem 1 %32
    • Use #0 Phillips screw driver to remove the two 2.5 x 5 mm Phillips #0 screws connecting the Wi-Fi card to the Motherboard.
  10. Acer Aspire V5-571-6889 Motherboard Replacement: passo 10, imagem 1 %32
    • Lift and pull out the Wi-Fi card.
  11. Acer Aspire V5-571-6889 Motherboard Replacement: passo 11, imagem 1 %32
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm Phillips #0 screw on the CD-ROM Drive.
  12. Acer Aspire V5-571-6889 Motherboard Replacement: passo 12, imagem 1 %32
    • Lift and pull out the CD-ROM Drive.
  13. Acer Aspire V5-571-6889 Motherboard Replacement: passo 13, imagem 1 %32
    • Use #0 Phillips screw driver to remove the 2 x 3 mm Phillips #0 screw holding down CD-ROM connector.
  14. Acer Aspire V5-571-6889 Motherboard Replacement: passo 14, imagem 1 %32
    • Pull out the CD-ROM Drive connector.
  15. Acer Aspire V5-571-6889 Motherboard Replacement: passo 15, imagem 1 %32 Acer Aspire V5-571-6889 Motherboard Replacement: passo 15, imagem 2 %32
    • Use Tweezers to remove the tape covering the display cable connector.
    • Gently disconnect the display cable connector.
  16. Acer Aspire V5-571-6889 Motherboard Replacement: passo 16, imagem 1 %32
    • Gently peel back the black cloth tape holding the wires in place.
  17. Acer Aspire V5-571-6889 Motherboard Replacement: passo 17, imagem 1 %32
    • Gently lift Motherboard.
    • Do not remove yet. There are some connections that need to be disconnected.
  18. Acer Aspire V5-571-6889 Motherboard Replacement: passo 18, imagem 1 %32
    • Gently remove the connector underneath the Motherboard.
  19. Acer Aspire V5-571-6889 Motherboard Replacement: passo 19, imagem 1 %32 Acer Aspire V5-571-6889 Motherboard Replacement: passo 19, imagem 2 %32 Acer Aspire V5-571-6889 Motherboard Replacement: passo 19, imagem 3 %32
    • Gently disconnect the three connectors attached to the Motherboard.
  20. Acer Aspire V5-571-6889 Motherboard Replacement: passo 20, imagem 1 %32
    • Use #0 Philips screw driver to unscrew the three 2.5 mm x 4 mm screws connecting the CPU fan to the Motherboard.
  21. Acer Aspire V5-571-6889 Motherboard Replacement: passo 21, imagem 1 %32
    • The motherboard is ready to be replaced.
    • Attach the CPU fan to the new motherboard during reassembling.
Conclusão
Samuel Miguel
Membro desde: 07/08/19
241 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G4, Harley Summer 2019 Membro de IUPUI, Team S2-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S2G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 604
