Ir para o conteúdo principal
Acer Aspire V5-571 Upper Cover Replacement
O que você precisa
  1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: passo 1, imagem 2 %32 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: passo 1, imagem 3 %32
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Upper  Cover Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571 Upper  Cover Replacement: passo 2, imagem 2 %32 Acer Aspire V5-571 Upper  Cover Replacement: passo 2, imagem 3 %32
  3. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: passo 3, imagem 1 %32 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: passo 3, imagem 2 %32 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: passo 4, imagem 1 %32 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: passo 4, imagem 2 %32 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: passo 4, imagem 3 %32
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Upper  Cover Replacement: passo 5, imagem 1 %32 Acer Aspire V5-571 Upper  Cover Replacement: passo 5, imagem 2 %32 Acer Aspire V5-571 Upper  Cover Replacement: passo 5, imagem 3 %32
    • Carefully separate the upper cover and remove it.
Conclusão
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 2,986
