Ir para o conteúdo principal
Acer Aspire V5-571 Optical Drive Replacement
O que você precisa
Vídeo de Apresentação
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: passo 1, imagem 2 %32 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: passo 1, imagem 3 %32
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Optical Drive Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571 Optical Drive Replacement: passo 2, imagem 2 %32 Acer Aspire V5-571 Optical Drive Replacement: passo 2, imagem 3 %32
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
Conclusão
4 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
2 comentários
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - Responder
Is it safe to use the laptop with the optical drive out?
Vianca - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 5,117
