Ir para o conteúdo principal
Acer Aspire V5-571 Keyboard Replacement
O que você precisa
Vídeo de Apresentação
  1. Acer Aspire V5-571 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire V5-571 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Acer Aspire V5-571 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    The two clips push toward the space-bar part of the keyboard. There are further clips around the edge of the keyboard, but it can be removed by careful prying with a thin blade screwdriver.
    ENT - Responder
  2. Acer Aspire V5-571 Keyboard Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571 Keyboard Replacement: passo 2, imagem 2 %32 Acer Aspire V5-571 Keyboard Replacement: passo 2, imagem 3 %32
    It would be helpful to have more info on how to remove the two cables. The larger one has a couple of clips that slide, but what exactly comes off? Do the plastic strips lift, or do the flat cables just pull out of them? Don't want to break something!
    ENT - Responder
    I watched several videos, many of which had the action hidden behind the keyboard. The larger ribbon pulls out of the strip after the two white clips on the end are moved. The smaller one has a black strip which lifts from the ribbon side, releasing the cable.
    ENT - Responder
Conclusão
Uma outra pessoa concluiu este guia.
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
Um comentário
Are you sure this is the right way to replace the keyboard? Or maybe this is just removing the keyboard and installing it back. WHAT IF the keyboard is broken and to be replaced with a new one?....
millerhoppins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 10,455
