Ir para o conteúdo principal
Acer Aspire V5-571 HDD SATA Cable Replacement
O que você precisa
Vídeo de Apresentação
  1. Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: passo 1, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: passo 1, imagem 3 %32
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 HDD SATA Cable Replacement: passo 2, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 2, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 2, imagem 3 %32
  3. Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: passo 3, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: passo 3, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: passo 4, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: passo 4, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: passo 4, imagem 3 %32
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 HDD SATA Cable Replacement: passo 5, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 5, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 5, imagem 3 %32
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): passo 6, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): passo 6, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): passo 6, imagem 3 %32
  7. Acer Aspire V5-571 HDD SATA Cable Replacement, Wi-Fi Half Mini PCIe card: passo 7, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Wi-Fi Half Mini PCIe card: passo 7, imagem 2 %32
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: passo 8, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: passo 8, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: passo 8, imagem 3 %32
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 HDD SATA Cable Replacement: passo 9, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 9, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 9, imagem 3 %32
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 HDD SATA Cable Replacement: passo 10, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 10, imagem 2 %32 Acer Aspire V5-571 HDD SATA Cable Replacement: passo 10, imagem 3 %32
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 HDD SATA Cable Replacement, HDD SATA Cable: passo 11, imagem 1 %32 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD SATA Cable: passo 11, imagem 2 %32
    • 13 pin SATA HDD Cable Adapter.
    • Did you do it successfully?
Conclusão
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.534 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Duração total: 4,678
