Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn off the laptop and remove the battery.
Remove two screws securing the Keyboard.
The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
Remove the Keyboard and disconnect the two flex cables:
Keyboard flex cable
Keyboard Light flex cable
Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
Slide the drive to the left and remove it.
Remove 4x phillips screws and disconnect:
Power On button flex cable
Touch pad flex cable
Remove 18x Phillips screws from the bottom cover.
Remove any memory SD Card from the Card reader.
Start opening with a plastic opening tool.
Gently remove the HDD and disconnect the SATA cable from it.
Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
Remove the Wi-Fi card.
Remove the Memory Cover.
Disconnect the Loudspeaker cable connector.
Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
Disconnect the LCD Display flex cable.
Disconnect the DC Jack cable.
Carefully remove the Optical drive SATA adapter.
We will disconnect the battery cable when we pick up the board.
Carefully pick up the Mother board and disconnect the Battery cable.
Disconnect the Fan cable.
Unscrew the screws that hold the Cooling system to the Mother board.
Carefully lift the Cooling system right up.
Use a lint-free cloth to clean the old thermal compound.
Use again cloth with isopropyl alcohol to clean the Thermal surface.
Remove three Philips screws held the Fan shield.
Unstick the black tape that hold the Fan to the cooler.
Unlock the clip and open the Fan case.
Close the Fan system.
Use the same technic to clean the surface of the processor from the old thermal compound
Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
Did you do it successful?
4 outras pessoas executaram este guia.
Um comentário
Hello!
Is ist possible to installa SSD storage to the V5-571G without removing the SATA?
Thanks for your reply
