Ir para o conteúdo principal
Acer Aspire V5-131-2680 Screen Replacement
O que você precisa
  1. Acer Aspire V5-131-2680 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Open up your laptop.
    • Place an opening tool in the crack between the screen and the back compartment. Drag the opening tool throughout the crack to open.
    • Remove the front black frame of the laptop.
  2. Acer Aspire V5-131-2680 Screen Replacement: passo 2, imagem 1 %32
    • Use a JIS #1 screwdriver to remove the 10 marked M2 x 3 Phillips screws.
    • Use a magnetic bit to fully remove the screws from their locations.
  3. Acer Aspire V5-131-2680 Screen Replacement: passo 3, imagem 1 %32
    • Remove then aluminum frame holding the screen in place.
    • This frame may have some sharp edges. Lift and remove slowly.
  4. Acer Aspire V5-131-2680 Screen Replacement: passo 4, imagem 1 %32
    • Carefully peel off the tape surrounding the screen.
  5. Acer Aspire V5-131-2680 Screen Replacement: passo 5, imagem 1 %32
    • Unplug the pin conector from the display.
    • This is a sensitive piece. Do not grab harshly or the pin can break.
    • The screen is now free to be removed.
Conclusão
Mauricio Moreno
Membro desde: 09/26/22
601 Reputação
Autoria de 5 guias
Equipe
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 7
Ao todo: 157
