Ir para o conteúdo principal
Acer Aspire V5-131-2680 Hard Drive Replacement
  1. Acer Aspire V5-131-2680 Hard Drive Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Hard Drive Replacement: passo 2, imagem 1 %32 Acer Aspire V5-131-2680 Hard Drive Replacement: passo 2, imagem 2 %32
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • On the sides of the hard drive, you will see two side tabs. This is what holds the hard drive in place.
    • Place your finger on the left tab and press on it to loosen the hard drive.
    • After the hard drive is loose, slide it out of the compartment.
    • Do not remove your finger from the side tab while removing the hard drive.
  4. Acer Aspire V5-131-2680 Hard Drive Replacement: passo 4, imagem 1 %32
    • You have successfully removed the hard drive from the laptop.
Conclusão
Mauricio Moreno
Membro desde: 09/26/22
601 Reputação
Autoria de 5 guias
Equipe
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 177
