Ir para o conteúdo principal
Acer Aspire V5-131-2629 Screen Replacement
O que você precisa
  1. Acer Aspire V5-131-2629 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Screen Replacement: passo 2, imagem 1 %32
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Screen Replacement: passo 3, imagem 1 %32
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Screen Replacement: passo 4, imagem 1 %32 Acer Aspire V5-131-2629 Screen Replacement: passo 4, imagem 2 %32
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Screen Replacement, Cover: passo 5, imagem 1 %32
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Screen Replacement: passo 6, imagem 1 %32 Acer Aspire V5-131-2629 Screen Replacement: passo 6, imagem 2 %32
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Screen Replacement, Screen: passo 7, imagem 1 %32 Acer Aspire V5-131-2629 Screen Replacement, Screen: passo 7, imagem 2 %32
    • Remove the screen bezel by lifting up the inside rim of the bezel and popping the edge out in steady upwards and outwards motions.
    • Complete this motion around the entire circumference of the bezel.
  8. Acer Aspire V5-131-2629 Screen Replacement: passo 8, imagem 1 %32 Acer Aspire V5-131-2629 Screen Replacement: passo 8, imagem 2 %32 Acer Aspire V5-131-2629 Screen Replacement: passo 8, imagem 3 %32
    • Remove the four Phillips screws from each of the mounting tabs in the corners of the screen.
  9. Acer Aspire V5-131-2629 Screen Replacement: passo 9, imagem 1 %32
    • Peel back the adhesive tape that runs the length of the bottom of the screen.
    • Be careful not to damage the cables which run between the tape and the screen.
  10. Acer Aspire V5-131-2629 Screen Replacement: passo 10, imagem 1 %32
    • Using the mounting tabs at the top corners of the screen, gently lift the screen up and out and lay it flat on the keyboard.
  11. Acer Aspire V5-131-2629 Screen Replacement: passo 11, imagem 1 %32
    • Remove the adhesive tape covering the gold-colored connector on the top left corner of the screen.
Conclusão
Aaron Almeida
Membro desde: 10/25/19
551 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 532
