Ir para o conteúdo principal
Acer Aspire V5-131-2629 Hard Drive Replacement
O que você precisa
  1. Acer Aspire V5-131-2629 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 2, imagem 1 %32
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 3, imagem 1 %32
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 4, imagem 1 %32 Acer Aspire V5-131-2629 Hard Drive Replacement: passo 4, imagem 2 %32
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Hard Drive Replacement, Cover: passo 5, imagem 1 %32
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 6, imagem 1 %32 Acer Aspire V5-131-2629 Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • Locate the large blue hard drive on the left side on the computer.
  8. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 8, imagem 1 %32
    • Gently pull out the ribbon cable on the computer-attached end.
  9. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 9, imagem 1 %32
    • Completely remove the hard drive from the hard drive bay.
  10. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 10, imagem 1 %32 Acer Aspire V5-131-2629 Hard Drive Replacement: passo 10, imagem 2 %32
    • Remove the two screws on the side of the hard drive cage.
  11. Acer Aspire V5-131-2629 Hard Drive Replacement: passo 11, imagem 1 %32 Acer Aspire V5-131-2629 Hard Drive Replacement: passo 11, imagem 2 %32
    • Pull the hard drive cage from the hard drive to separate the two.
Conclusão
4 outras pessoas executaram este guia.
Nicole B Bosse
Membro desde: 10/27/19
175 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 1,631
