Introdução
Your touch pad is not working and you want to replace it in the safest way possible? Are you confused with the steps you need to take in order to replace your touch pad? This guide will teach you how to do so step by step.
O que você precisa
Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
Remove the remaining 9 visible screws, which are 5mm in length.
Start by carefully removing the ribbon cable that is plugged into the touch pad.
To remove it, gently pull the ribbon cable away from the slot that it is seated in.
Uma outra pessoa concluiu este guia.
