Introdução
If your wireless connection is inconsistent or unresponsive the network card may be faulty. Use this guide to replace the network card and get back online.
O que você precisa
Remove the nine 4mm screws with a PH0 screwdriver.
Remove the two 6mm screws with a PH0 screwdriver.
Remove the wire connector from the network card using a plastic opening tool.
Quase terminado!
Conclusão
