Ir para o conteúdo principal
Acer Aspire V3-771G Hard Drive Replacement
O que você precisa
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: passo 2, imagem 1 %32 Acer Aspire V3-771G Hard Drive Replacement: passo 2, imagem 2 %32 Acer Aspire V3-771G Hard Drive Replacement: passo 2, imagem 3 %32
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: passo 3, imagem 1 %32 Acer Aspire V3-771G Hard Drive Replacement: passo 3, imagem 2 %32
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: passo 4, imagem 1 %32 Acer Aspire V3-771G Hard Drive Replacement: passo 4, imagem 2 %32
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: passo 5, imagem 1 %32 Acer Aspire V3-771G Hard Drive Replacement: passo 5, imagem 2 %32 Acer Aspire V3-771G Hard Drive Replacement: passo 5, imagem 3 %32
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
Conclusão
9 outras pessoas executaram este guia.
David Walker
Membro desde: 10/11/14
341 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-36, Donnelly Fall 2014 Membro de USF Tampa, Team 1-36, Donnelly Fall 2014
USFT-DONNELLY-F14S1G36
1 Membro
1 Guia de autoria
Um comentário
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 30
Duração total: 13,640
