Introdução
If you’ve cracked or damaged the screen of your Acer Aspire V3-571G laptop, it may be time for a replacement. To complete this replacement, you will need a few tools, so make sure to check the Tools List below before starting this replacement. This guide will help you properly and safely replace the screen on your Acer Aspire laptop.
O que você precisa
Turn the laptop upside down to locate the battery at the top of the laptop.
Use a screwdriver to shift the orange lever to the right.
Use a pair of tweezers to carefully remove the two small pieces of plastic at the bottom of the screen.
5 outras pessoas executaram este guia.
