Ir para o conteúdo principal
Acer Aspire V3-551-8887 Keyboard Replacement
O que você precisa
  1. Acer Aspire V3-551-8887 Keyboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Keyboard Replacement: passo 2, imagem 1 %32 Acer Aspire V3-551-8887 Keyboard Replacement: passo 2, imagem 2 %32
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Keyboard Replacement, USB Ports: passo 3, imagem 1 %32
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Keyboard Replacement: passo 4, imagem 1 %32 Acer Aspire V3-551-8887 Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Keyboard Replacement: passo 6, imagem 1 %32 Acer Aspire V3-551-8887 Keyboard Replacement: passo 6, imagem 2 %32
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Keyboard Replacement: passo 7, imagem 1 %32 Acer Aspire V3-551-8887 Keyboard Replacement: passo 7, imagem 2 %32
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Keyboard Replacement: passo 8, imagem 1 %32
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Keyboard Replacement: passo 9, imagem 1 %32
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Keyboard Replacement, Keyboard: passo 10, imagem 1 %32
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Keyboard Replacement: passo 11, imagem 1 %32 Acer Aspire V3-551-8887 Keyboard Replacement: passo 11, imagem 2 %32
    • Use a spudger to gently lift the keyboard.
Conclusão
3 outras pessoas executaram este guia.
Alexander Lazar
Membro desde: 04/22/14
357 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-8, Regan Spring 2014 Membro de Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Membros
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 6,775
