Introdução
Removing the back panel gives access to most everything else in the laptop.
Peças
Nenhum componente especificado.
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Uma outra pessoa concluiu este guia.
Um comentário
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
