Introdução
The Random Access Memory (RAM) stores information that needs to be retrieved quickly or often. The RAM is one common component in a laptop that fails often and needs to be replaced. Use this guide to replace broken the RAM on your Acer Aspire V3-551-8469 laptop. No complicated manipulation is required.
O que você precisa
To release the battery, slide the orange tab to the right with a spudger.
The battery is now released and can be picked up and set to the side.
