Ir para o conteúdo principal
Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement
O que você precisa
  1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 2, imagem 1 %32
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 3, imagem 1 %32 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 3, imagem 2 %32
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
  5. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 5, imagem 1 %32
    • After removing the back panel, use a Phillips #1 screwdriver to unscrew the two 8 mm screws that hold the retaining piece to the frame.
  6. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 6, imagem 1 %32 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 6, imagem 2 %32
    • Pull the plastic tab toward the frame to disconnect the hard drive SATA.
  7. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove the hard drive from the laptop, and use a Phillips #1 screwdriver to unscrew the two 3 mm screws that secure the retaining piece to the hard drive.
Conclusão
Ian Smiley
Membro desde: 03/26/19
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 634
