Ir para o conteúdo principal
Acer Aspire TimelineX 4820T-6645 Wifi Module Replacement
O que você precisa
  1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Battery: passo 1, imagem 1 %32
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: passo 2, imagem 1 %32
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: passo 3, imagem 1 %32 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: passo 3, imagem 2 %32
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: passo 4, imagem 1 %32 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: passo 4, imagem 2 %32
    • Flip the laptop over and remove screws (PH#1, 8mm length) holding the back cover in place
    • Remove back cover from your laptop
  5. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: passo 5, imagem 1 %32 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: passo 5, imagem 2 %32
    • Disconnect the two antenna cables from the WLAN board as shown below
    • Black wire is terminal 1(left), white wire is terminal 2(right)
  6. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: passo 6, imagem 1 %32
    • Remove the screw(PH#1, 3mm length) holding the WLAN board to the laptop
  7. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: passo 7, imagem 1 %32
    • Detach and remove the WLAN board from the WLAN socket
Conclusão
Dylan Bryda
Membro desde: 03/26/19
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 258
