Introdução
In this guide, you will be able to replace your laptop's RAM with step by step help. The RAM is located on the motherboard.
O que você precisa
Turn laptop so under side is facing up.
Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
Pry open the cover using the Spudger tool.
After removing the motherboard, turn it over so that the back side is facing you.
