Ir para o conteúdo principal
Acer Aspire TimelineX 1830T-68U118 RAM Replacement
O que você precisa
  1. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: passo 1, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: passo 1, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: passo 1, imagem 3 %32
    • Remove the device's battery before beginning.
    • Turn laptop so under side is facing up.
    • Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
  2. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 2, imagem 1 %32
    • Pry open hard drive cover using the Spudger tool.
  3. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 3, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 3, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 3, imagem 3 %32
    • Remove screw attached to the hard drive using the PH0 mm Phillips Head.
    • The hard drive can now be removed from the device.
  4. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: passo 4, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: passo 4, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: passo 4, imagem 3 %32
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  5. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 5, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 5, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 5, imagem 3 %32
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  6. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 6, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  7. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 7, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 7, imagem 2 %32
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  8. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 8, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 8, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 8, imagem 3 %32
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  9. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, RAM: passo 9, imagem 1 %32
    • After removing the motherboard, turn it over so that the back side is facing you.
  10. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 10, imagem 1 %32
    • To release the RAM from the motherboard, press both of the metal prongs on the sides of the RAM.
  11. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 11, imagem 1 %32
    • After RAM memory card is released from the motherboard, hold the RAM card on a 45 degree angle and remove the card.
  12. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: passo 12, imagem 1 %32
    • Install your new RAM memory card following these steps in reverse.
Conclusão
Um comentário
Stupid! you can remove the ram after step 2!!!
Erlend - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 558
