Ir para o conteúdo principal
Acer Aspire TimelineX 1830T-68U118 Fan Replacement
O que você precisa
  1. Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
  2. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 2, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 2, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 2, imagem 3 %32
    • Hold the battery release button, and pull the battery out of the laptop.
  3. Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Fan: passo 3, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Fan: passo 3, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement, Fan: passo 3, imagem 3 %32
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  4. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 4, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 4, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 4, imagem 3 %32
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  5. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 5, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 5, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  6. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 6, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 6, imagem 2 %32
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  7. Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 7, imagem 1 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 7, imagem 2 %32 Acer Aspire TimelineX 1830T-68U118 Fan Replacement: passo 7, imagem 3 %32
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 1,230
