Ir para o conteúdo principal
Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement
O que você precisa
  1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: passo 1, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: passo 1, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: passo 1, imagem 3 %32
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover with the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 2, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 2, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 2, imagem 3 %32
    • Lift up on the ZIF connector that secures the ribbon cable using the opening tool.
    • Pull the ribbon cable free.
  3. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 3, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 3, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 3, imagem 3 %32
    • Remove the 4, 2.5 mm screws from the trackpad cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 4, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 4, imagem 2 %32
    • Remove the metal piece that secures the trackpad cover in place using the opening tool.
  5. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 5, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 5, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: passo 5, imagem 3 %32
    • Remove the trackpad using the opening tool and your hands.
Conclusão
Grecia Corrada
Membro desde: 03/19/18
1.134 Reputação
Autoria de 6 guias
Equipe
Baylor, Team S3-G3, Williams Spring 2018 Membro de Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 868
