Ir para o conteúdo principal
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
O que você precisa
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: passo 1, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: passo 1, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: passo 1, imagem 3 %32
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 2, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 2, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 2, imagem 3 %32
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 3, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 3, imagem 2 %32
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 4, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 4, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 4, imagem 3 %32
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 5, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 5, imagem 2 %32
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 6, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 6, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 6, imagem 3 %32
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 7, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 7, imagem 2 %32
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 8, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 8, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 8, imagem 3 %32
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 9, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 9, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: passo 9, imagem 3 %32
    • Pull the docking connector off of the screen section.
Conclusão
Grecia Corrada
Membro desde: 03/19/18
1.134 Reputação
Autoria de 6 guias
Equipe
Baylor, Team S3-G3, Williams Spring 2018 Membro de Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
Membros da 3
Autoria de 6 guias
Um comentário
Where do you get the docking ports or whatever it is called? With the magnets
Michael - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Duração total: 2,911
