Introdução
If your device is not charging or turning on, you may need to replace the internal battery on your device. Before attempting to replace the battery, please visit the troubleshooting page for this device. If you have attempted the recommendations on the troubleshooting page and the device is still not functioning properly, you can replace the internal battery in your device. Carefully follow the steps in this guide to replace the battery.
O que você precisa
Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
Lift this side of the back cover once the opening tool is inside the device.
Use the opening tool and your hands to gradually work around the edges of the cover.
4 outras pessoas executaram este guia.
