Ir para o conteúdo principal
Acer Aspire Switch 10 SW5-012-18MY Battery Replacement
O que você precisa
  1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 2, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 2, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 2, imagem 3 %32
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 3, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 3, imagem 2 %32
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 4, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 4, imagem 2 %32
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 5, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 5, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 5, imagem 3 %32
    • Use the opening tool to lift the ZIF connector holding the ribbon cable in place on the circuit board.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 6, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 6, imagem 2 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 6, imagem 3 %32
    • Remove the piece of thin, black tape that is attached to the circuit board on the other side of the battery.
    • Use the opening tool to lift the black ZIF connector holding the ribbon cable in place.
  7. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 7, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 7, imagem 2 %32
    • Partially remove the piece of black tape that is holding the bundled cable connector to the battery in place.
    • Pull on the battery's bundled cable connector to unplug it from the circuit board.
  8. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 8, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove the 3 mm screw that is holding the battery in place.
  9. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 9, imagem 1 %32
    • Gently remove the ribbon cable from the battery.
  10. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 10, imagem 1 %32 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: passo 10, imagem 2 %32
    • Carefully remove the battery from the device by lifting it up.
Conclusão
4 outras pessoas executaram este guia.
Grecia Corrada
Membro desde: 03/19/18
1.134 Reputação
Autoria de 6 guias
Equipe
Baylor, Team S3-G3, Williams Spring 2018 Membro de Baylor, Team S3-G3, Williams Spring 2018
BU-WILLIAMS-S18S3G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 45
Duração total: 4,527
