Ir para o conteúdo principal
Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
O que você precisa
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: passo 1, imagem 1 %32
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 2, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 2, imagem 2 %32
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 3, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 3, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 3, imagem 3 %32
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: passo 4, imagem 1 %32
    • Remove the touchpad.
Conclusão
Max Francois
Membro desde: 09/28/16
684 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-4, Passmore Fall 2016 Membro de USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 Membros
Autoria de 4 guias
1Comentário do guia
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 21
Ao todo: 1,638
