Ir para o conteúdo principal
Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement
O que você precisa
  1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: passo 1, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: passo 1, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: passo 1, imagem 3 %32
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 2, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 2, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 2, imagem 3 %32
    • There is one zero insertion force connector that needs to be removed.
    • Use your plastic opening tool to flip up the black clip that secures the ribbon cable to the motherboard.
    • Once the clip is flipped up, the ribbon cable will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 3, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 3, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 3, imagem 3 %32
    • To remove the four bundled cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  4. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 4, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 4, imagem 2 %32
    • Use a pair of tweezers to gently pull up the speaker closest to the motherboard.
  5. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 5, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 5, imagem 2 %32
    • Remove any tape that may be holding down the speakers or wires in place.
  6. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 6, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 6, imagem 2 %32
    • Use tweezers to gently pull up the second speaker.
  7. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: passo 7, imagem 1 %32
    • Remove and replace the speakers.
Conclusão
Richard Colon
Membro desde: 09/28/16
480 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-4, Passmore Fall 2016 Membro de USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,345
