Ir para o conteúdo principal
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
O que você precisa
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 2, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 2, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 2, imagem 3 %32
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 3, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 3, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 3, imagem 3 %32
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 4, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 4, imagem 2 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 4, imagem 3 %32
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 5, imagem 1 %32 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: passo 5, imagem 2 %32
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
Conclusão
9 outras pessoas executaram este guia.
Max Francois
Membro desde: 09/28/16
684 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-4, Passmore Fall 2016 Membro de USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 25
Duração total: 7,370
