Ir para o conteúdo principal
Acer Aspire S7-392-6484 LCD Replacement
O que você precisa
  1. Acer Aspire S7-392-6484 LCD Replacement, LCD: passo 1, imagem 1 %32 Acer Aspire S7-392-6484 LCD Replacement, LCD: passo 1, imagem 2 %32
    • Use a heat gun to heat the edges of the screen, loosening the adhesive underneath.
    • Run a jimmy or similarly thin object around the edge of the screen.
    • Using a suction cup, lift up on the screen to separate it from the adhesive.
    • Be aware that the screen will most likely crack significantly during these steps. Be prepared to immediately replace the LCD should you undertake this repair.
  2. Acer Aspire S7-392-6484 LCD Replacement: passo 2, imagem 1 %32 Acer Aspire S7-392-6484 LCD Replacement: passo 2, imagem 2 %32
    • Turn over the display to show the connectors underneath.
    • Disconnect the marked connectors to remove the display from the casing.
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Wise
Membro desde: 02/14/18
754 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Ao todo: 1,826
