Ir para o conteúdo principal
Acer Aspire S7-392-6484 Solid State Drive Replacement
O que você precisa
  1. Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: passo 1, imagem 1 %32 Acer Aspire S7-392-6484 Solid State Drive Replacement, Fan: passo 1, imagem 2 %32
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  2. Acer Aspire S7-392-6484 Solid State Drive Replacement: passo 2, imagem 1 %32 Acer Aspire S7-392-6484 Solid State Drive Replacement: passo 2, imagem 2 %32
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  3. Acer Aspire S7-392-6484 Solid State Drive Replacement, Solid State Drive: passo 3, imagem 1 %32
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  4. Acer Aspire S7-392-6484 Solid State Drive Replacement: passo 4, imagem 1 %32
    • Remove the hard drive by pulling it away horizontally from its connection.
Conclusão
3 outras pessoas executaram este guia.
Nicholas Wise
Membro desde: 02/14/18
754 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G6, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 23
Duração total: 2,600
