Ir para o conteúdo principal
Acer Aspire S3-951-6432 Wi-Fi Card Replacement
O que você precisa
  1. Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Battery: passo 1, imagem 2 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Battery: passo 1, imagem 3 %32
    • Keeping it closed, turn the laptop upside down.
    • With the Phillips #0 screwdriver, remove the twelve 5 mm screws that hold the laptop together.
    • Insert the plastic opening tool between the plastic casings to pull the bottom lid of the laptop up.
    • You do not need to pull the lid all the way off.
  2. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 2, imagem 2 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip.
    • Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket.
    • The battery is now disconnected. If you want to remove the battery, follow the remaining steps in this guide. However, if you only wish to disconnect the battery to do other internal work, skip the remaining steps in this guide and continue on to other guides.
  3. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 3, imagem 1 %32
    • With the Phillips #0 screwdriver, remove the two 5 mm screws that are located above the long black piece of the battery.
  4. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 4, imagem 2 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 4, imagem 3 %32
    • Locate the two speakers for this laptop that are connected above the battery by a thin red cord.
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the left speaker in place.
    • Pull the left speaker up along with the red cord and leave it off to the right side.
    • If you plan to disassemble the laptop down to the motherboard, you will also need to remove the two 3 mm screws holding the right-side speaker in place with a Phillips #0 screwdriver.
  5. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Without bending it, lift the entire battery (both the long black piece and the rectangular blue piece) straight up. Place it off to one side.
  6. Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Wi-Fi Card: passo 6, imagem 1 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement, Wi-Fi Card: passo 6, imagem 2 %32
    • Locate the Wi-Fi card (it is near the black rectangular hard drive).
  7. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 7, imagem 1 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 7, imagem 2 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 7, imagem 3 %32
    • Lift up and remove the two cables attached to the Wi-Fi card (one is white and one is black) with the spudger tool.
  8. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 8, imagem 1 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 8, imagem 2 %32
    • Remove the single 3 mm screw located on the top-right side of the Wi-Fi card using the Phillips #0 screwdriver.
    • After replacing the Wi-Fi card, make sure that the cables are aligned. Otherwise, you could damage the metal connectors on the chip.
  9. Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 9, imagem 1 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 9, imagem 2 %32 Acer Aspire S3-951-6432 Wi-Fi Card Replacement: passo 9, imagem 3 %32
    • Lift and remove the Wi-Fi card.
Conclusão
Cynthia Bennett
Membro desde: 10/17/18
584 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S1-G1, Rose Fall 2018 Membro de UW Tacoma, Team S1-G1, Rose Fall 2018
UWT-ROSE-F18S1G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 1,706
