Ir para o conteúdo principal
Acer Aspire S3-391-6046 Screen Replacement
O que você precisa
  1. Acer Aspire S3-391-6046 Screen Replacement, Screen: passo 1, imagem 1 %32 Acer Aspire S3-391-6046 Screen Replacement, Screen: passo 1, imagem 2 %32 Acer Aspire S3-391-6046 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Slide the plastic opening tool underneath the frame of your device.
    • Slide the plastic opening tool all around the frame until the entire frame becomes loose and comes off.
  2. Acer Aspire S3-391-6046 Screen Replacement: passo 2, imagem 1 %32 Acer Aspire S3-391-6046 Screen Replacement: passo 2, imagem 2 %32 Acer Aspire S3-391-6046 Screen Replacement: passo 2, imagem 3 %32
    • On the bottom left of the screen there is a black cable with a piece of white tape over it. Remove the white tape by peeling it off.
    • Slide your opening tool underneath the front of the cable, and pull the cable upwards to disconnect it from its socket.
  3. Acer Aspire S3-391-6046 Screen Replacement: passo 3, imagem 1 %32 Acer Aspire S3-391-6046 Screen Replacement: passo 3, imagem 2 %32 Acer Aspire S3-391-6046 Screen Replacement: passo 3, imagem 3 %32
    • Peel the silver tape from the corner of your laptop until it fully comes off.
  4. Acer Aspire S3-391-6046 Screen Replacement: passo 4, imagem 1 %32 Acer Aspire S3-391-6046 Screen Replacement: passo 4, imagem 2 %32 Acer Aspire S3-391-6046 Screen Replacement: passo 4, imagem 3 %32
    • Remove the screen by grabbing the edges of the screen and pulling forward.
Conclusão
6 outras pessoas executaram este guia.
2 comentários
Hi! Apparently three films came off with the LCD. Clear,gray and black what are they?
Coolboy_Awesome - Responder
Thank you. Excellent instructions allowing me to replace LCD ribbon
M Geyer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 1,675
