Ir para o conteúdo principal
Acer Aspire S3-391-6046 Keyboard Replacement
O que você precisa
  1. Acer Aspire S3-391-6046 Keyboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Keyboard Replacement: passo 2, imagem 1 %32 Acer Aspire S3-391-6046 Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Keyboard Replacement: passo 3, imagem 1 %32
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Remove the four Phillips #0 screws that are connected to the left and right speakers.
    • Carefully disconnect the wires that connect the speaker to the rest of the computer.
  5. Acer Aspire S3-391-6046 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove two Phillips #0 screws that are beside the ends of the gray wire.
  6. Acer Aspire S3-391-6046 Keyboard Replacement: passo 6, imagem 1 %32 Acer Aspire S3-391-6046 Keyboard Replacement: passo 6, imagem 2 %32 Acer Aspire S3-391-6046 Keyboard Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the gray wire slowly with tweezers.
    • Carefully peel wire off.
  7. Acer Aspire S3-391-6046 Keyboard Replacement: passo 7, imagem 1 %32 Acer Aspire S3-391-6046 Keyboard Replacement: passo 7, imagem 2 %32
    • Slowly remove the two wires that are to the left of the battery with tweezers in an upward pulling motion.
  8. Acer Aspire S3-391-6046 Keyboard Replacement: passo 8, imagem 1 %32 Acer Aspire S3-391-6046 Keyboard Replacement: passo 8, imagem 2 %32
    • Completely remove the battery out of its position.
  9. Acer Aspire S3-391-6046 Keyboard Replacement: passo 9, imagem 1 %32 Acer Aspire S3-391-6046 Keyboard Replacement: passo 9, imagem 2 %32
    • Remove the five Phillips #0 screws that are on the border of the laptop.
    • Disconnect the white wire that is below the fan.
  10. Acer Aspire S3-391-6046 Keyboard Replacement: passo 10, imagem 1 %32 Acer Aspire S3-391-6046 Keyboard Replacement: passo 10, imagem 2 %32
    • Flip all of the circuits upwards.
    • Remove all Phillips #0 screws.
    • Remove the keyboard.
Conclusão
Brian Jimenez
Membro desde: 09/18/18
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 847
