Introdução
This guide will be used when a battery will not charge when connected to a charger. The battery is connected to many wires, so when disconnecting wires be cautious as the wires could become damaged and will also need to be replaced.
O que você precisa
With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
