Ir para o conteúdo principal
Acer Aspire S3-391-6046 Battery Replacement
O que você precisa
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: passo 2, imagem 1 %32 Acer Aspire S3-391-6046 Battery Replacement: passo 2, imagem 2 %32
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: passo 3, imagem 1 %32
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: passo 4, imagem 1 %32
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: passo 5, imagem 1 %32 Acer Aspire S3-391-6046 Battery Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: passo 6, imagem 1 %32 Acer Aspire S3-391-6046 Battery Replacement: passo 6, imagem 2 %32
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: passo 7, imagem 1 %32 Acer Aspire S3-391-6046 Battery Replacement: passo 7, imagem 2 %32
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 734
