Introdução
This guide will walk you through removing the speakers. The speakers may need to be removed if they are damaged, or just to access the components beneath them.
O que você precisa
Remove the 12 5mm Phillips #00 screws.
Use a plastic opening tool to gently pry open the back panel.
Gently lift up the back panel, exposing the internals of the laptop.
Quase terminado!
Conclusão
