Ir para o conteúdo principal
Acer Aspire S3 MS2346 Keyboard Replacement
O que você precisa
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: passo 1, imagem 1 %32 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: passo 1, imagem 2 %32 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: passo 2, imagem 1 %32 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: passo 2, imagem 2 %32 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: passo 2, imagem 3 %32
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: passo 3, imagem 1 %32 Acer Aspire S3 MS2346 Keyboard Replacement: passo 3, imagem 2 %32
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: passo 4, imagem 1 %32
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: passo 5, imagem 1 %32 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: passo 5, imagem 2 %32
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: passo 6, imagem 1 %32
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: passo 7, imagem 1 %32
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: passo 8, imagem 1 %32 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: passo 8, imagem 2 %32 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: passo 8, imagem 3 %32
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: passo 9, imagem 1 %32
    • Gently lift the board exposing the keyboard assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,463
