Ir para o conteúdo principal
Acer Aspire S3 MS2346 Display Assembly Replacement
O que você precisa
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: passo 1, imagem 2 %32 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: passo 2, imagem 1 %32 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: passo 2, imagem 2 %32 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: passo 2, imagem 3 %32
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: passo 3, imagem 1 %32 Acer Aspire S3 MS2346 Display Assembly Replacement: passo 3, imagem 2 %32
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: passo 4, imagem 1 %32
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: passo 5, imagem 1 %32 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: passo 5, imagem 2 %32
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: passo 6, imagem 1 %32
    • Unlatch the screen from the frame
Conclusão
3 outras pessoas executaram este guia.
Equipe
3 comentários
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - Responder
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 30
Duração total: 3,116
