Ir para o conteúdo principal
Acer Aspire S3 MS2346 Battery Replacement
O que você precisa
  1. Acer Aspire S3 MS2346 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Acer Aspire S3 MS2346 Battery Replacement, Back Cover: passo 1, imagem 2 %32 Acer Aspire S3 MS2346 Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Battery Replacement, Speakers: passo 2, imagem 1 %32 Acer Aspire S3 MS2346 Battery Replacement, Speakers: passo 2, imagem 2 %32
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  3. Acer Aspire S3 MS2346 Battery Replacement: passo 3, imagem 1 %32
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  4. Acer Aspire S3 MS2346 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Gently lift the battery from the frame.
Conclusão
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 15
Ao todo: 4,440
