Ir para o conteúdo principal
Acer Aspire R7-371T-72CF Wifi Chip Replacement
O que você precisa
  1. Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: passo 1, imagem 1 %32 Acer Aspire R7-371T-72CF Wifi Chip Replacement, Wifi Chip: passo 1, imagem 2 %32
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 2, imagem 1 %32
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 3, imagem 1 %32 Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 3, imagem 2 %32 Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 3, imagem 3 %32
    • Locate the wifi chip, as shown to the left.
    • The chip can by identified by the white and black wires connected to it, as well as a single screw holding it in place.
  4. Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 4, imagem 1 %32 Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 4, imagem 2 %32 Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 4, imagem 3 %32
    • Locate the 2 antenna wires connected to the chip.
    • One is black, and the other is white.
    • Use a spudger or plastic opening tool to carefully disconnect the wires from the chip by prying upwards.
    • The connectors 'click' into place, like a button.
  5. Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 5, imagem 1 %32 Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 5, imagem 2 %32
    • Remove the Phillips #00 6mm securing screw using your screwdriver.
  6. Acer Aspire R7-371T-72CF Wifi Chip Replacement: passo 6, imagem 1 %32
    • Remove the chip by pulling towards the edge of the computer.
Conclusão
Dylan Meintser
Membro desde: 09/27/17
476 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S8-G5, Banghart Fall 2017 Membro de Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
Membros da 5
Autoria de 5 guias
Um comentário
Any idea on screen replacement for this particular model? I’ve been searching for a video all week. Please help me out if possible
Hasan Mahmood - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 542
