Ir para o conteúdo principal
Acer Aspire R7-371T-72CF Power Port Replacement
O que você precisa
  1. Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: passo 1, imagem 1 %32 Acer Aspire R7-371T-72CF Power Port Replacement, Power Port: passo 1, imagem 2 %32
    • Turn off your laptop and disconnect the power adapter.
    • Locate and remove all 12 Phillips #00 6mm screws on the backside of the laptop.
  2. Acer Aspire R7-371T-72CF Power Port Replacement: passo 2, imagem 1 %32
    • Using your prying tool, carefully remove the back panel.
  3. Acer Aspire R7-371T-72CF Power Port Replacement: passo 3, imagem 1 %32 Acer Aspire R7-371T-72CF Power Port Replacement: passo 3, imagem 2 %32 Acer Aspire R7-371T-72CF Power Port Replacement: passo 3, imagem 3 %32
    • Locate the power connector, as shown on the left.
    • The power connector will be in the same location as where you normally plug the charger into the laptop to charge your device.
  4. Acer Aspire R7-371T-72CF Power Port Replacement: passo 4, imagem 1 %32 Acer Aspire R7-371T-72CF Power Port Replacement: passo 4, imagem 2 %32 Acer Aspire R7-371T-72CF Power Port Replacement: passo 4, imagem 3 %32
    • Disconnect the wiring from the motherboard, and pull out the rest of the wire carefully.
    • Make sure the wire is not caught on anything before pulling.
  5. Acer Aspire R7-371T-72CF Power Port Replacement: passo 5, imagem 1 %32
    • Pull out the power connector by pulling upwards on the wires.
    • This may require a small amount of force, but should pop out with some pressure.
Conclusão
Uma outra pessoa concluiu este guia.
Ethan Frey
Membro desde: 09/27/17
117 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S8-G5, Banghart Fall 2017 Membro de Cal Poly, Team S8-G5, Banghart Fall 2017
CPSU-BANGHART-F17S8G5
Membros da 5
Autoria de 5 guias
4 comentários
What’s the part number for the power jack cable, and who sells it?
AcerFan - Responder
50.mqpn7.001 (SIQDD0ZS8AD001)
I found it here: https://www.itpartsource.com/50MQPN7001-...
Jorge Prado - Responder
What model is this? Is this the older (~2015) model with the small cylindrical charging port?
Sarah - Responder
The associated part id numbers for the Acer R7-371t 45W DC Jack Cable are:
50.MQPN7.001
SIQDD0ZS8AD001
Unfortunately, I have found this part impossible to find in stock at any source.
rosemank - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 1,699
